| | | Forums66 Topics128,024 Posts1,055,392 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 3 New Guy | | New Guy Joined: Apr 2009 Posts: 3 | was wondering if a 53 gmc 100 was pos or neg ground and how to tell got truck as project and every wire was cut off and trown in a box
53 gmc 100
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | A 53 would have been born a 6 volt positive ground. However, about the only difference in wiring with positive ground is the polarity at the battery, at the ammeter and at the distributor. | | | | | Joined: Apr 2009 Posts: 3 New Guy | | New Guy Joined: Apr 2009 Posts: 3 | how about gauges would it hurt to use them as a negative ground and also generator? thanks
53 gmc 100
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | You will need a negative ground regulator and then polarize the generator. The temp and oil pressure should be mechanical. I think the fuel gauge should work. I really don't see a need to change polarity of you are going to stay with 6 volt. | | | | | Joined: Apr 2009 Posts: 3 New Guy | | New Guy Joined: Apr 2009 Posts: 3 | not sure yet thinking might eventualy go 12v
53 gmc 100
| | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | Not sure why you want to go thru all the work of converting to a neg system. The only reason you need to go the 12V route is because you intend to go with modern day electronics. Just a suggestion from someone who's been there. Cecil....... | | |
