0 members (), 140 guests, and 0 robots.
Topics128,260
Posts1,058,343
Members48,485
#524367 04/03/2009 9:55 PM
was wondering if a 53 gmc 100 was pos or neg ground and how to tell got truck as project and every wire was cut off and trown in a box
53 gmc 100
clops79 #524385 04/03/2009 11:10 PM
A 53 would have been born a 6 volt positive ground. However, about the only difference in wiring with positive ground is the polarity at the battery, at the ammeter and at the distributor.
crenwelge #524420 04/04/2009 12:41 AM
how about gauges would it hurt to use them as a negative ground and also generator? thanks
53 gmc 100
clops79 #524544 04/04/2009 7:25 AM
You will need a negative ground regulator and then polarize the generator. The temp and oil pressure should be mechanical. I think the fuel gauge should work. I really don't see a need to change polarity of you are going to stay with 6 volt.
crenwelge #524607 04/04/2009 3:42 PM
not sure yet thinking might eventualy go 12v
53 gmc 100
clops79 #525656 04/07/2009 5:30 AM
Not sure why you want to go thru all the work of converting to a neg system. The only reason you need to go the 12V route is because you intend to go with modern day electronics. Just a suggestion from someone who's been there. Cecil.......
