3 members (Eileen, Uncles51, 1 invisible), 86 guests, and 3 robots.
Topics128,079
Posts1,056,296
Members48,441
Probably been discussed before..
I finally have the final parts ordered for my Toyota power steering conversion. Just looking for an escape route incase I have problems. I have a 55, 2nd 3/4 ton truck.
Incase the new drag link end for the drivers wheel is made for a 1/2 ton..is it different from a 3/4 ton? In that case I think I could swap a 1/2 ton steering arm?
Keith
The drag link is the same 1/2 thru 1 ton on the '55-'59s.
Bill Burmeister
Slickriffs,
How about a write-up on your power steering conversion with pictures? I am considering the same thing on my '56.
Best wishes,
Les
Roadmarks: read these links. I like the one using a "stage 1" kit from American Classis best. See what you think. It shows both the AD truck and the TF truck.
http://www.classictruckshop.com/t1.php
http://www.classicperform.com/tech_articles/Power-Steering-Trucks/Power-Steering-Trucks.htm
As I said I like the first one better. (just my opinion)
In fact, I worked at Advance today and can order me a gear box for $116 my cost with a core which I have. Then I plan to order the kit with the drag link from American Classic, then get my pitman arm from a junk yard or order it through Advance Auto.
I'm going to use a 68 truck column I already have. Since I can get a decent discount at Advance I'm gonna probably end up ordering new pump and hoses from them.
The first article is pretty good on details and pictures.
I also looked up the steering boxes for all the years they say to use and found that 68-74 used the same part # while the other years changed a time or two. I don't know the #'s changed but figured I would stay with the one for the most years. I don't think ratio's will make that much difference since its power steering anyway.
Should you decide you want me to order you one let me know. You could pick it up while down here for the Southern Stovebolters Reunion in May smile
EDIT: Les, I think I can come out with about $300 doing mine. Its $116 for the box, $130 for the kit but take off 10%, and I can get new pump and hoses for about $75 and probably get the pitman arm at salvage yard for $5....a friend may give me one.
Wow, that's fabulous! Looks like just what a person needs to be able to get the side clearance you need for a V8.
Have you driven it yet? How does it feel compared with the stock steering? Does it help cure the terrible bump steer that the stock systems suffer from?
52 GMC 3/4 ton pickup
68 Big Block Vette
68 455 Firebird
keith,
please post pics and details on what you did for this conversion, because i also want to install power steering in my 57.
thanks.
leonard
1957 Chevy 3100 1/2-Ton
Photobucket pictures
OK will do when the time comes..at this time I have the Toyota box which I bought on Ebay-the bracket,pitman and drag link have been ordered.
Keith
