7 members (BCBill, Gdads51, Lightholder's Dad, joe apple, Hawkman, greenie-reddy, TUTS 59),
190
0
Mod | | | Forums66 Topics128,101 Posts1,056,176 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 208 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 208 | Just brought home my 58 - 3200 last week. I honestly have not played much with the inside because I need to replace the rear main seal first & I have the truck taken apart.
Today - while waiting for my stinkey pete to show up, I decided to take a look around.
Headlights do not turn on, but dash & parking lights do. My first thought was maybe a fuse.
I can't find the fuse box!
There is nothing under the dash - so I looked under the hood. Nothing there either.
Any ideas? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | there was no fuse panel standard on the TF trucks, they only got one if there was accessory electrical stuff ordered [radio, etc - it was on the inside firewall just above the clutch, looks like this] - the light switch has one fuse on it for the light circuit, and also has a pair of heat sensitive bi-metal type "circuit breakers" for the headlights alone .... could also be the switch itself, the dimmer switch, or wiring Bill | | | | | Joined: Mar 2009 Posts: 208 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 208 | WOW! thanks Bill. I have no fuse box. The truck came with no radio (delete plate still there) & what looks like an add on heater with just a toggle switch, so I'd say no box fits your description.
The previous owner said they used to work fine, but they wouldn't light for him when I bought it. I'll check the switch/ fuses first.
The wiring in the truck (what there is of it) is in really good condition compared to other cars I've owned.
I assume the fuse / bi-metal brakers on the switch right, not on the firewall? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, it's easiest to check'em out if you take the switch loose from the dash - pic from assembly manual - the bi-metal doobers are the metal arms with contact points on each side - but it could just be a wire has come unplugged from the switch or dimmer Bill | | | | | Joined: Mar 2009 Posts: 208 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 208 | Funny you mention a wire from the dimmer.
There are maybe 6 wires in the whole truck, so while working out the old main seal this afternoon - I though it unusual to see a broken wire under there near the floor. I think I just found my issue.
I'm out on vacation for the next week - wish I could work on it. | | |
