3 members (klhansen, Nick in Manitou, UtahYork), 82 guests, and 4 robots.
Topics128,080
Posts1,055,953
Members48,430
#524012 04/02/2009 11:43 PM
Just brought home my 58 - 3200 last week. I honestly have not played much with the inside because I need to replace the rear main seal first & I have the truck taken apart.
Today - while waiting for my stinkey pete to show up, I decided to take a look around.
Headlights do not turn on, but dash & parking lights do. My first thought was maybe a fuse.
I can't find the fuse box!
There is nothing under the dash - so I looked under the hood. Nothing there either.
Any ideas?
1958 Chevy Apache 3200
bone stock 235
53k miles
3 on the tree
there was no fuse panel standard on the TF trucks, they only got one if there was accessory electrical stuff ordered [radio, etc - it was on the inside firewall just above the clutch, looks like this] - the light switch has one fuse on it for the light circuit, and also has a pair of heat sensitive bi-metal type "circuit breakers" for the headlights alone .... could also be the switch itself, the dimmer switch, or wiring
WOW! thanks Bill. I have no fuse box. The truck came with no radio (delete plate still there) & what looks like an add on heater with just a toggle switch, so I'd say no box fits your description.
The previous owner said they used to work fine, but they wouldn't light for him when I bought it. I'll check the switch/ fuses first.
The wiring in the truck (what there is of it) is in really good condition compared to other cars I've owned.
I assume the fuse / bi-metal brakers on the switch right, not on the firewall?
bone stock 235
53k miles
3 on the tree
yes, it's easiest to check'em out if you take the switch loose from the dash - pic from assembly manual - the bi-metal doobers are the metal arms with contact points on each side - but it could just be a wire has come unplugged from the switch or dimmer
Funny you mention a wire from the dimmer.
There are maybe 6 wires in the whole truck, so while working out the old main seal this afternoon - I though it unusual to see a broken wire under there near the floor. I think I just found my issue.
I'm out on vacation for the next week - wish I could work on it.
bone stock 235
53k miles
3 on the tree
