2 members (Eisenholtz, Peggy M),
46
Mod | | | Forums66 Topics128,022 Posts1,055,376 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#52415 11/14/2005 11:16 PM | Joined: Aug 2006 Posts: 90 New Guy | | New Guy Joined: Aug 2006 Posts: 90 | I have the opportunity to purchase a corvette carb setup for 235 engine. It has the intake manifold, the 3 1 barrel carbuuretors and the linkage. I would be putting it on my '54 3600.
What do you guys think? Is it a good setup and is it easy to install? Are modifications needed or does it bolt right up to a stock 235?
Thanks fo your input/help!
Steve
Today is the best day of my life!!!
#52416 11/15/2005 2:06 AM | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | i think that someone made a post about this earlier, if you look through the back logs of this section and the general discussion one. it seems that i remember that it was a workable setup, but i am not the right one to ask....happy hunting.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | |
#52417 11/15/2005 3:47 AM | Joined: May 2005 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 45 | It will bolt right up to the engine. Do some checking to see if anything on the firewall will hit the back carburetor. This is where most of the problems come from when putting the corvette intake on other cars or trucks. I know they won't fit a 55 chevy. because the back carburetor hits the master cyl. | | |
#52418 11/15/2005 4:12 AM | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | I just bought and then sold one. I was planning on using it for my 62 C-10. I didn't have the carbs or the linkage. The price of those and the complexity of the linkage influenced my decision not to use them. The rear carb was VERY close to the firewall and I would have had to reroute the clutch line from the MC at the very least. Also unable to use the corvette aircleaner in the rear. Your application will be totally different but I'm hoping you can make it work. I'd love to see that on one of these trucks for something different. | | |
#52419 11/15/2005 7:11 PM | Joined: Aug 2006 Posts: 90 New Guy | | New Guy Joined: Aug 2006 Posts: 90 | Thanks for the input! I could not find a related thread. I will keep looking though.
It sounds like I need to be careful as far as clearance around firewall for both the back card and aircleaner. Does anyone have measurements/pics/part numbers of the corvette air cleaners?
Thanks again!!!
#52420 11/16/2005 2:56 AM | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Here you go. I found a link with an excellent picture of the 235 engine with the 3 side draft carbs. I hope this helps you. Scroll down and click on the engine picture to get a larger view. http://proteamcorvette.com/cars/NSN-EH53.htm
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | |
