3 members (Otto Skorzeny, msmall, 1 invisible),
143
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,137 Posts1,056,471 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 77 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 77 | Hi, Can anyone tell me if the tail light lenses were held in by sheetmetal screws, or something like an 8-32 or 10-32 machine screw? I suspect mine were all stripped and that explains the #10 sheetmetal screws. Thanks.
Pete | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | I believe that they ere 8/32 machine screws. This is what other years use. | | | | | Joined: Mar 2004 Posts: 77 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 77 | I believe that they ere 8/32 machine screws. This is what other years use. Thank you! Pete | | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | Sorry for the late reply--I just remembered to go out and check, and my '62 Suburban has sheet metal screws holding the tail light lenses in.
I believe these to be original, as I've pulled another set of lenses off a junkyard Suburban and they also had sheetmetal screws, and the spare tail light housings I have from Ebay don't have any kind of boss, screw or anything with enough metal to support machine screw threads.
-Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Mar 2004 Posts: 77 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 77 | Sorry for the late reply--I just remembered to go out and check, and my '62 Suburban has sheet metal screws holding the tail light lenses in.
-Brad Brad, That makes sense as that is what I see on mine. They were #10 screws I think, I wonder if they could have been #8's originally? Thanks. Pete | | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | I don't know the size... or really even where to check! But the screw head fits nicely in the recess of the lens.
There isn't a lot of play between the diameter of the screw, and the ID of the hole in the plastic lens.
