5 members (TooMany2count, tclederman, Gray_Ghost, 2 invisible), 85 guests, and 0 robots.
Topics128,132
Posts1,056,386
Members48,441
Hi,
Can anyone tell me if the tail light lenses were held in by sheetmetal screws, or something like an 8-32 or 10-32 machine screw?
I suspect mine were all stripped and that explains the #10 sheetmetal screws.
Thanks.
Pete
I believe that they ere 8/32 machine screws. This is what other years use.
Thank you!
Pete
Sorry for the late reply--I just remembered to go out and check, and my '62 Suburban has sheet metal screws holding the tail light lenses in.
I believe these to be original, as I've pulled another set of lenses off a junkyard Suburban and they also had sheetmetal screws, and the spare tail light housings I have from Ebay don't have any kind of boss, screw or anything with enough metal to support machine screw threads.
-Brad
SOUTHERN FALL GABfest
October 6 ~ Commerce, Georgia
Details here!
Never Pee on an Electric Fence.
-Brad
Brad,
That makes sense as that is what I see on mine.
They were #10 screws I think, I wonder if they could have been #8's originally?
Thanks.
Pete
I don't know the size... or really even where to check! But the screw head fits nicely in the recess of the lens.
There isn't a lot of play between the diameter of the screw, and the ID of the hole in the plastic lens.
-Brad
Details here!
