| | | Forums66 Topics128,101 Posts1,056,180 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | I've just finish putting a new Mar-K floor in my truck.Wheel tubs are steel and have a flange that rests on the wood. Here's my question.Should I apply a sealant in the wheel well where the wood and the steel meet,to stop wheel spray getting in the box? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | A '52 doesn't have wheel tubs and the floor should only be surounded by bed sides, a front and tailgate. Are you talking about a different truck then the '52??? DG
Denny G Sandwich, IL
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | Well,I guess I didn't explain properly,sorry.I've installed 4" wide tubs for clearance for the wide tires I run.Therefore the outward board on each side has been cut to follow the shape of the tub | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....then of coarese some sealant is needed. It was used in couple places on my 52panel. | | |
