| | | Forums66 Topics128,204 Posts1,057,302 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 100 | I have a 1965 chevy c20 with an inline 6. I have just bought it and only driven it twice, about 30 miles on both trips.It was running like a champ, real strong. Yesterday on my second trip it drove fine the first 15 miles to my sisters house, then when i went to leave i got a few feet down the road and it just choked out.
What it's doing:
It idles perfectly, and when normal gas is applied through the pedal it revs fine. However, if you press the pedal or the throttle arm quick to the floor it sounds like it is sucking air and after doing this 3 to 4 times consecutivly it backfires loudly. I would also like to mention that the choke and its compents are confusing at best and do not look stock, but they worked fine the first 45 miles.
When its driving:
It seems to run ok, not as good as the first 45 miles, in first and second gear but when i shift to 3rd it does not respond to the gas pedal and if its getting a load like an uphill it will eventual shut the truck off. I checked the timing and distrubutor, it checked out good.
It's better to have it and not need it, then it is to need it and not have it. "Woodrow F. Call"
| | | | | Joined: Nov 2002 Posts: 2,774 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,774 | Sounds like a clogged fuel filter.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Or a fuel pump that is going south. | | | | | Joined: Feb 2008 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 130 | I was thinking of a grain of dirt in the main jet. | | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | I would have to agree with the Cabking on this 1. sounds like a fuel flow problem | | | | | Joined: Mar 2009 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 100 | i will try a new filter tonight and run it through the neighborhood.
| | | | | Joined: Mar 2009 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 100 | what are the chances its the carburetor
| | | | | Joined: Feb 2007 Posts: 33 Apprentice | | Apprentice Joined: Feb 2007 Posts: 33 | I have been fooled by point gap, the fibre block wears and you don't have any gap and the thunder is taken from the engine.
Do you have any loose plug wires?
if dwell and gap are fine along with timing, Get a clean rag, remove air cleaner, open the butterfly and build rpm, at a high, cover the air intake with the rag and keep the throttle open, this will choke the engine down when it slows, remove the rag and let it build rpm, repeat a few times and see if this backflushes the jets. Sometimes it is enough to get whole again. | | | | | Joined: Mar 2009 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 100 | i have tried all of your suggestions to no avail. I think i will put a new carb on it
| | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | Best of luck to you Ms. I have tried all suggestions to no avail. Jerry
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Check for a blockage at the tank. Pull the line at the fuel pump and blow back towards tank. Lots of crud builds up over the years, Scott | | |
