0 members (),
160
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 12 New Guy | | New Guy Joined: Feb 2009 Posts: 12 | Curious what pit falls i might encounter.
Looking for panel or suburban in excellent shape. Long time hotrodder.
| | | | | Joined: Jan 2007 Posts: 446 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 446 | FUEL MILEAGE! The 292 in my '65 Suburban drinks gas like a fish..water..
Check the rear differential. I'm changing mine to 353 gears to up the MPG.
As far as the install, you will have to wait for someone more qualified to answer that. Someone will come along here soon.
Iron Clad | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | "Caroline's Truck" put a 292 into an early Chevy. They have a quite detailed post and pictures if you want to do a search. | | | | | Joined: Dec 2007 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 96 | I am in the process now. My 53 was a 3/4 ton truck. Engine mounts are available from Tom Langdon: http://www.stoveboltengineco.com/acartpro/category.asp?catcode=39I am using a IFS crossmember from a 78 Chevy truck and a 700R4 auto transmission. I reused the original trans crossmember, but had to move it back. Also had to trim the firewall, but if you are willing to run an electric fan you might not have to cut it. | | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | i put on in my 49 burb i used a 54 bellhousing x member a 55 v8 bellhousing and ordered the side mounts, i did not cut the firewall the head is right against it i have a gmc frame and i am running a stock fan blade | | | | | Joined: Feb 2009 Posts: 12 New Guy | | New Guy Joined: Feb 2009 Posts: 12 | Thanks guys for all the help. Now im on the search for a good core or running engine here in Alaska.
