6 members (MickeyP, 37 GC, Youngin' Tut 59, Bill Hanlon, UtahYork, wilbur53), 116 guests, and 2 robots.
Topics128,147
Posts1,056,805
Members48,454
Curious what pit falls i might encounter.
Looking for panel or suburban in excellent shape. Long time hotrodder.
I
I Offline
FUEL MILEAGE! The 292 in my '65 Suburban drinks gas like a fish..water..
Check the rear differential. I'm changing mine to 353 gears to up the MPG.
As far as the install, you will have to wait for someone more qualified to answer that. Someone will come along here soon.
Iron Clad
"Caroline's Truck" put a 292 into an early Chevy. They have a quite detailed post and pictures if you want to do a search.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
I am in the process now. My 53 was a 3/4 ton truck. Engine mounts are available from Tom Langdon: http://www.stoveboltengineco.com/acartpro/category.asp?catcode=39
I am using a IFS crossmember from a 78 Chevy truck and a 700R4 auto transmission. I reused the original trans crossmember, but had to move it back. Also had to trim the firewall, but if you are willing to run an electric fan you might not have to cut it.
http://community.webshots.com/user/49chevyman?vhost=community
"The only people who do not make mistakes, are people who do not do anything."
i put on in my 49 burb i used a 54 bellhousing x member a 55 v8 bellhousing and ordered the side mounts, i did not cut the firewall the head is right against it i have a gmc frame and i am running a stock fan blade
1949 SUBURBAN
Thanks guys for all the help. Now im on the search for a good core or running engine here in Alaska.
