1 members (klhansen),
101
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,151 Posts1,056,999 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 14 New Guy | | New Guy Joined: Mar 2009 Posts: 14 | | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | DavidWymore, Kool...looks like lots of hard work ahead. I see a 'brownie' in one of the pix. That alone makes it worth the effort. Good luck. Stuart | | | | | Joined: Jul 2004 Posts: 2,991 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,991 | Anytime you save one from the crusher it's a good thing! | | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | whats up with the TF inthe backround? | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Those are cool as is. I like the mirror arms. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Mar 2009 Posts: 14 New Guy | | New Guy Joined: Mar 2009 Posts: 14 | | | | | | Joined: Mar 2009 Posts: 14 New Guy | | New Guy Joined: Mar 2009 Posts: 14 | | | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | lol ok why did davidwymore put a dodge up there lol .. why david why :P
1937 1/2 ton
| | | | | Joined: Jul 2004 Posts: 2,991 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,991 | Dave, TF stands for Task Force, which is what the '55 through '59's were called. One of your photos showed one of them in the background. That's what micron was asking about.
| | | | | Joined: Jul 2006 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 79 | lol ok why did davidwymore put a dodge up there lol .. why david why :P becuase if you look at the first two pictures in the album , it shows him loading the AD truck on a trailer attached to the dodge , simple . Nice find, David. | | | | | Joined: Nov 1995 Posts: 5,740 24601 | | 24601 Joined: Nov 1995 Posts: 5,740 | David, It would be easier, and we could tell you more, if you gave us the casting numbers on the blocks. They should be on the block just to the front of the distributor. 6 or 7 digits.
While you're at it, the head casting number would be usefull, as well. It is located on the driver's side, forward of the caburetor and on the flat part of the flange (where the manifolds bolt up) Sometimes they are pretty well obscured by crud.
Other things to look for that will aid our id process:
Are the valve covers held on by 4 screws at the edges, or two acorn nuts in the top center?
Has the sheet metal around the front top of the radiator been cut/mangled/hacked?
Thanks, John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Mar 2009 Posts: 14 New Guy | | New Guy Joined: Mar 2009 Posts: 14 | I gave the 4 window to a buddy, have a potential buyer for the 5 window with the brownie. How much should I ask for it? I have no idea... | | |
