| | | Forums66 Topics128,089 Posts1,056,130 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 25 | If I change engines maybe to a 235cid, would I have to change tranny, driveline, and rear end????  | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | The short answer is "no". Your 216 bell housing will bolt right up to the 235. Search around here in the forums, this is a pretty popular upgrade. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | The main problem will be the water pump issue, but it really isn't much of an issue and is easily fixed. Read the forums, there is a ton of info in here. | | | | | Joined: Dec 2006 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 25 | If I go the other way and put an novz rearend and driveline do I need to change the tranny?? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Do you have an original 3-speed or a 4-speed? The the original 3-speed will not work with an open drive shaft. The original 4-speed can be adapted to an open driveshaft but wait to hear first-hand opinions on this.
| | | | | Joined: Dec 2006 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 25 | It has a 4 speed (3 with a compound low) | | |
