7 members (Donf, Hanks custodian, Cosmo, Gray_Ghost, treegrower, Bill Hanlon, 1 invisible), 105 guests, and 1 robot.
Topics128,080
Posts1,055,956
Members48,430
#521616 03/27/2009 5:53 PM
If I change engines maybe to a 235cid, would I have to change
tranny, driveline, and rear end???? smile
The short answer is "no". Your 216 bell housing will bolt right up to the 235. Search around here in the forums, this is a pretty popular upgrade.
waldo53 #521627 03/27/2009 6:36 PM
The main problem will be the water pump issue, but it really isn't much of an issue and is easily fixed. Read the forums, there is a ton of info in here.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
If I go the other way and put an novz rearend and driveline
do I need to change the tranny??
Do you have an original 3-speed or a 4-speed? The the original 3-speed will not work with an open drive shaft. The original 4-speed can be adapted to an open driveshaft but wait to hear first-hand opinions on this.
It has a 4 speed (3 with a compound low)
