2 members (tclederman, Phak1),
37
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,090 Posts1,056,031 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | Can someone direct me to any previous thread discussing how to refurbish your cab mounted gas tank? Specifically, how can I clean the inside? I've heard some reccomend hydrochloric acid, but then others discourage it's use saying it causes flash rust later on. I've been using phosphoric acid this week on rusted bolts with very good results and wonder why I couldn't pour a gallon of that in and let it sit overnight? Seems it would neutralize any rust inside and not be as caustic as hydrochloric.
I have no major rust, leaks or pin holes to deal with. Tank is in great shape. Any suggestions on how to take care of the inside while I have it out would be appreciated.
Spot
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | We used to clean saddle tanks with rubbing alcohol. It removes the varnish doesn't really damage anything else. We used to buy alcohol in 5 gallon cans and injected it into the air system as an airline anti freeze. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Can someone direct me to any previous thread discussing how to refurbish your cab mounted gas tank? Spot Just to the right of the "Active Topics" link above is the "Search" link. Putting Gas Tank in the search box will yield hours of reading. FYI if you use any type of acid in your tank you will need to coat the inside of the tank to prevent rusting.
| | | | | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | There is a product out there called Cream. It is a kit that has an acid etcher and a white milkey substance that seales the tank on the inside. I have used this stuff and it works. Follow the instructions to the letter (NO SHORT CUTS) and it works well. I went a step further than the instructions say by putting a good solvent like varsol and some glass fishtank beads inside the tank. I sealed off the openings and shook the tank rotating it and shaking it some more untill all the big parts were loosened. Then i started the Cream treatment. It is very urgrant that all (ALL) of the excess cream is drained from the tank when coating is complete. (IT WILL NOT STICK TO ITSELF AND WILL NEVER DRY IF LEFT IN A POOL INSIDE THE TANK!!!!!)
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I've used Kreem and RedKote and by far prefer RedKote. The Kreem kits include phosphoric acid as the cleaner/etcher.
| | | | | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | I took mine to a local radiator shop & had it cleaned out, redkoted inside & blackkoted on the lower outside & new plug for $100.00 1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | | | | Joined: Mar 2009 Posts: 54 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 54 | I had a 1975 International 1/2 ton pickup a few years back with cruddy, rusted up tanks. A mechanic friend of mine put a couple of big scoops of rough edged gravel in each one, fastened them to the front of an old cement mixer, and just let them rotate for several hours. Worked like one of those small rock polishing machines, and the tanks cleaned up really well. Might not make you too popular with your neighbors though, if they live close by. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I have taken the tanks out of my trucks, had them boiled clean at a radiator shop, and pressure tested. Each time I buy new tanks. It seems like this whole process with any of the tank sealer is close to the cost of a new tank.
I go with new tanks over recoated used leaky tanks. If you don't coat them right the stuff comes/flakes off and you will have a problem when you least want it.
You can always cut a hole in the old tank, mount it on the wall and use it for a rag container or nostalgic shelf unit.
My 2 centavos.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Dennis, I know where your coming from but some of us have no option as there is not a tank available.....or I would have bought one for my panel. Your point is well taken though. | | | | | Joined: Aug 2008 Posts: 52 New Guy | | New Guy Joined: Aug 2008 Posts: 52 | I spent ALOT of time and money cleaning my cab mounted fuel tank. It had rust and some gooey tar from years of sitting. After debating for a while, and seeing the effects of these repairs over a long period, I ended up buying a new tank last week. POR15 has a great kit for tank restoration and sealing if you decide to go that route | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | I soaked mine in muriatic acid and water for a few days, then pressurewashed. I then used POR15 tank repair on the inside [IMG]http://thumb7.webshots.net/t/63/463/8/24/57/2184824570101989507JvfaqM_th.jpg[/IMG]
| | | | | Joined: Jan 2009 Posts: 18 New Guy | | New Guy Joined: Jan 2009 Posts: 18 | i've used the electrolosis method on motorcycle tanks with very good results; using a battery charger and washing powder. i can post a link if your search here comes up short... very easy and the resulting coating can be left as is, or coated ed
ed s.
it's better to beg forgivness, than to ask permission.....
| | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | Thanks for all the suggestions guys. I appreciate it.
Spot
