0 members (),
170
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2008 Posts: 54 | I am installing the connecting rod cap bolts on my 261 and have found the torque specification of 35-45 ft. lbs. for the nut, but I don't see a value for the lock nuts. They seem way too flimsy for 40 ft.lbs. Is there a published value? If not, any advice? | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Quite honestly, I usually throw them away.
Drew
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Are you asking about a stamped steel lock nut (pal nut) used on 216's? If so the shop manual says to turn them down until they touch then 1/2 turn more.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I think that you mean 216 not 261, correct? Well it is a bit of a mystery why they were used in the first place. I did use the "pal nuts" on my 216 though. You basically snug them and then turn a bit more. I don't actually think they are needed. | | | | | Joined: Mar 2008 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2008 Posts: 54 | It's a 261. It had the nuts on the rod cap nuts when I removed the rods. Maybe the PO put them on? Does a 261 not normally have them? | | | | | Joined: Mar 2008 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2008 Posts: 54 | It is a stamped steel nut, but the 261 manual doesn't mention them. I am beginning to think they shouldn't be there on a 261. | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | My 261 does not have them. Just regular rod nuts. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I believe 1954 was the last year to use these.
