2 members (texczech, 78buckshot), 110 guests, and 6 robots.
Topics128,078
Posts1,056,035
Members48,433
#520550 03/24/2009 11:27 PM
I am installing the connecting rod cap bolts on my 261 and have found the torque specification of 35-45 ft. lbs. for the nut, but I don't see a value for the lock nuts. They seem way too flimsy for 40 ft.lbs. Is there a published value? If not, any advice?
Quite honestly, I usually throw them away.
Drew
Are you asking about a stamped steel lock nut (pal nut) used on 216's?
If so the shop manual says to turn them down until they touch then 1/2 turn more.
My Blog
I think that you mean 216 not 261, correct? Well it is a bit of a mystery why they were used in the first place. I did use the "pal nuts" on my 216 though. You basically snug them and then turn a bit more. I don't actually think they are needed.
1951 1 Ton Completed
It's a 261. It had the nuts on the rod cap nuts when I removed the rods. Maybe the PO put them on? Does a 261 not normally have them?
It is a stamped steel nut, but the 261 manual doesn't mention them. I am beginning to think they shouldn't be there on a 261.
My 261 does not have them. Just regular rod nuts.
I believe 1954 was the last year to use these.
My Blog
