1 members (Bill Hanlon),
340
Mod | | | Forums66 Topics128,159 Posts1,057,039 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 243 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 243 | ok guys who makes running boards or bed sides for a 48 Chevrolet 1 ton single wheel truck? what parts are different from a 3/4 to a 1 ton single wheel step side? any repo companies making repo parts like bed wood? sides? boards for a long wheel base 1 ton | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Both Chevrolet and GMC used to make bed sides and running boards for these trucks. Your best bet is to look for a used set. I've never heard of anyone reproducing these parts for a 1-ton.
Bed sides, the running boards and the curved panel that goes between are the primary differences in the body parts. The frame is longer on the 1-ton.
I don't know specifically on a '48, but by '54 the 1-ton had a completely open driveline. I'm pretty sure the '49 I took apart a while back was comletely open also, though I don't know that it was original.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Aug 2008 Posts: 52 New Guy | | New Guy Joined: Aug 2008 Posts: 52 | If it helps, I have a 1951 1 ton dually. Basically, other than body parts, there is nothing on mine that matches the 1/2 tons, but quite a bit of the brake, steering, and chassis parts are compatable with the 3/4 ton. The front axle, king pins, master cylinder and wheel cylinders match for sure. To follow up on OldSub's comments, my driveline is completely open. | | | | | Joined: Sep 2008 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 77 | Dbone, If you could get good deminsions from someone, a local sheetmetal shop should be able to break new bedsides for you. The stake pockets, tailgate and headbaord piece should be the same as the smaller trucks and you can order them from any of the vendors. You may also be able to get the fab shop to make the curved piece as well. The running boards are a different story. I am assuming your truck was a flat bed when you got it and you want to change to the stepside bed. | | |
