Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
7 members (Hotrod Lincoln, wvstovebolt, carbking, Jay R, Wayne67vert, Otto Skorzeny, 1 invisible), 113 guests, and 4 robots.
Topics128,287
Posts1,058,544
Members48,491
ok guys who makes running boards or bed sides for a 48 Chevrolet 1 ton single wheel truck? what parts are different from a 3/4 to a 1 ton single wheel step side? any repo companies making repo parts like bed wood? sides? boards for a long wheel base 1 ton
Both Chevrolet and GMC used to make bed sides and running boards for these trucks. Your best bet is to look for a used set. I've never heard of anyone reproducing these parts for a 1-ton.
Bed sides, the running boards and the curved panel that goes between are the primary differences in the body parts. The frame is longer on the 1-ton.
I don't know specifically on a '48, but by '54 the 1-ton had a completely open driveline. I'm pretty sure the '49 I took apart a while back was comletely open also, though I don't know that it was original.
If it helps, I have a 1951 1 ton dually. Basically, other than body parts, there is nothing on mine that matches the 1/2 tons, but quite a bit of the brake, steering, and chassis parts are compatable with the 3/4 ton. The front axle, king pins, master cylinder and wheel cylinders match for sure. To follow up on OldSub's comments, my driveline is completely open.
Dbone,
If you could get good deminsions from someone, a local sheetmetal shop should be able to break new bedsides for you. The stake pockets, tailgate and headbaord piece should be the same as the smaller trucks and you can order them from any of the vendors. You may also be able to get the fab shop to make the curved piece as well. The running boards are a different story. I am assuming your truck was a flat bed when you got it and you want to change to the stepside bed.
