0 members (),
109
Mod | | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 72 | Got my new motor in and it seems sluggish. This is a 430hp, Gen 1, 350 built be The Engine Factory. Motor was supposed to be tuned from the factory, but I thought the truck seems sluggish. Have searched online, but figured I might get another opinion. According to them it should be set at 32 degrees at 3000rpm. | | | | | Joined: Aug 2008 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 72 | This motor is going into my 65 K10 with an SM420 manual transmission. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Does it have the power at the upper RPM range? Most hi-po engines have all of the power at the upper end because of cam design and wouldn't work to well behind a truck 4 speed, Scott | | | | | Joined: Aug 2008 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 72 | Yes, so far most of the power is at the upper end 2000rpm and up.
| | | | | Joined: Aug 2008 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 72 | If that turns out to be the case, and A different tranny is needed, what are your suggestions?
| | | | | Joined: Mar 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 92 | I would put an RV cam in it and bring the power band down, Scott | | | | | Joined: Aug 2008 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 72 | Guess I need to do some research. Thanks guys. | | | | | Joined: Jan 2008 Posts: 239 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 239 | 32 degrees total is very little. I do perfromance tuning, and usually end up in the 36-38 degree range for total, all in by 3000 rpm, and 18-20 initial. More timing increases vacuum which makes it run much better. Use a vacuum advance as well, with 10-15 degrees of advance built in. You should be able to cruise under no load at 48-55 degrees of total advance.
A performance engine can run with a SM420 trans, but tuning is critical. The torque band needs to be widened as much as possible. You have the cubes to build the torque, so make the best of what you have.
Devin
If you can't hose it out it ain't a truck
55 3100 63 Corvair Monza 64 El Camino 72 240Z 01 Suburban
| | | | | Joined: Aug 2008 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 72 | Thanks 55 tractor, I figure it might be time to hand it over to a mechanic because with me being a "Rookie" mechanic, (and when I say rookie, I am being very kind to myself!), the possibility of tanking this engine after all the money and time I spent on it realllly scares me! I did all this so that I could learn by doing, but I was expecting to do all my learning while I was driving my truck with it's new engine, and rebuilding the old 350 that came out of it. As it is I'm just about out of my one year warranty on the new engine, and it's only got about 2.5 hours on it.  | | | | | Joined: Feb 2004 Posts: 29,774 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,774 | Are you running a regular HEI distributor, or someone's aftermarket design? Most stock distributors require some pretty radical work to the centrifugal advance system to get the right amount of initial advance without over-advancing the centrifugal. I usually reduce the centrifugal advance by about 10 degrees by shortening the length of the slots they move in, and adding the same amount to the initial advance. I like 12 degrees of initial, 24 degrees of centrifugal, maxing out at 2800-3000 RPM, and 10 degrees of vacuum for a total advance of 46 degrees at 3,000 RPM with no load. Jerry
| | | | | Joined: Aug 2008 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 72 | Thanks Lincoln, will have to run this by my "specialist" as soon as I can get him over. | | |
