5 members (UtahYork, Gdads51, Cletus1950, Hotrod Lincoln, MickeyP), 81 guests, and 3 robots.
Topics128,150
Posts1,056,985
Members48,460
DavidWymore,
Kool...looks like lots of hard work ahead. I see a 'brownie' in one of the pix. That alone makes it worth the effort. Good luck. thumbs_up
Stuart
Anytime you save one from the crusher it's a good thing!
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
1 Offline
whats up with the TF inthe backround?
Big Bolt Forum Co-moderator
Those are cool as is. I like the mirror arms.
1948 Chevy 2-Ton
TF?
lol ok why did davidwymore put a dodge up there lol .. why david why :P
1937 1/2 ton
Dave,
TF stands for Task Force, which is what the '55 through '59's were called. One of your photos showed one of them in the background. That's what micron was asking about.
Rich
1947 Loadmaster
becuase if you look at the first two pictures in the album , it shows him loading the AD truck on a trailer attached to the dodge , simple . Nice find, David.
1955 Chevrolet 3100 2nd
1954 International Harvester R-110
My Webshots Pictures
Ok, how bout some help with the engine numbers? I'm told these old ones are identified/registered by the engine numbers. Are there more I need to find? One is supposed to be a '49 and one a '50. Don't know if engines are original.
[IMG]http://i142.photobucket.com/albums/r118/DavidWhymore/FOR%20SALE/OldChevyEnginenumberwithbox.jpg[/IMG]
[IMG]http://i142.photobucket.com/albums/r118/DavidWhymore/FOR%20SALE/OldChevyEnginenumberwithbrownie.jpg[/IMG]
24601
24601
David, It would be easier, and we could tell you more, if you gave us the casting numbers on the blocks. They should be on the block just to the front of the distributor. 6 or 7 digits.
While you're at it, the head casting number would be usefull, as well. It is located on the driver's side, forward of the caburetor and on the flat part of the flange (where the manifolds bolt up) Sometimes they are pretty well obscured by crud.
Other things to look for that will aid our id process:
Are the valve covers held on by 4 screws at the edges, or two acorn nuts in the top center?
Has the sheet metal around the front top of the radiator been cut/mangled/hacked?
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
I gave the 4 window to a buddy, have a potential buyer for the 5 window with the brownie. How much should I ask for it? I have no idea...
