1 members (Hotrod Lincoln), 57 guests, and 1 robot.
Topics128,094
Posts1,056,066
Members48,433
#16007 11/24/2003 3:26 PM
Occasionally my 3 speed will get stuck in 3rd gear, and I have to get out and pull the linkage up and then I'm fine. Can I tighten this linkage up or am I possibly missing a clip or other part? Any input is appreciated.
Not quite as lean
Not quite as mean, but
Still a Marine!
#16008 11/25/2003 1:58 AM
Is it getting stuck going from 2nd to 3rd? When you pull up on the linkage, are you pulling it straight up into 2nd from under the hood? John.
1968 Chevy C-10, 250 and 3 speed on floor, Hedman headers, Offy intake, Edelbrock 600cfm 4 barrel, HEI
1966 Chevy C-10, motor and tranny went into the '68. Waiting to be restored.
#16009 11/25/2003 3:44 AM
It gets stuck in 3rd gear. I have to push the linkage down to unstick it.
Not quite as lean
Still a Marine!
Apprentice
Apprentice
I have this same symptom in my '49 1/2-ton. Three speed on the column. It seems to happen at slow speeds - if I downshift before slowing, then I avoid the problem. Once stuck, I can't move the shifter and it stays in 3rd until I stop, open the hood, and pull up on the shift linkage.
Wondering if it is in the linkage adjustment, but I haven't wanted to mess that up by tinkering with it.
Any ideas out there?
Greg - 49 1/2 ton
GregNY #518158 03/17/2009 9:00 PM
Riding in the Passing Lane
You need to pull the box on the column off & rebuild it. You can build up the worn parts with weld. Make shure all the linkages & bushings are free of play. The adjustment should be so the gearshift lever is in the same possition when you pull forward & back in neutral.
1972 Chevy c10 Cheyenne Super
Apprentice
Apprentice
The worn parts will be obvious? Corners off? I have checked the shifter position forward/back in neutral, per my shop manual, and that seems okay. Checked the linkages... appear okay, so you are probably right on the box internals. Just not sure what I should expect to see.
Thanks.
Greg - 49 1/2 ton
GregNY #518574 03/18/2009 10:35 PM
Yes it will be pretty obvious when you get it tore down. The idea is to keep the selecter lever from getting between the 2 parts. If the shaft is loose you can rub the cover over some sand paper to narrow the holes.
Apprentice
Apprentice
Thanks. Once I get some time, I will take a look. Appreciate the advice!
Greg - 49 1/2 ton
GregNY #518870 03/19/2009 7:48 PM
Some times the culprit is actually the shifter arms on the transmission. I am talking about the arms the linkage bolts to. Years of shifting can loosen up the connections here, and even wear them significantly. Check to see you have good contact on the arms, and the keyway where it bolts.
