0 members (),
126
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#16007 11/24/2003 3:26 PM | Joined: Jun 2003 Posts: 54 Member | | Member Joined: Jun 2003 Posts: 54 | Occasionally my 3 speed will get stuck in 3rd gear, and I have to get out and pull the linkage up and then I'm fine. Can I tighten this linkage up or am I possibly missing a clip or other part? Any input is appreciated.
Not quite as lean Not quite as mean, but Still a Marine!
#16008 11/25/2003 1:58 AM | Joined: Jul 2003 Posts: 55 Member | | Member Joined: Jul 2003 Posts: 55 | Is it getting stuck going from 2nd to 3rd? When you pull up on the linkage, are you pulling it straight up into 2nd from under the hood? John.
1968 Chevy C-10, 250 and 3 speed on floor, Hedman headers, Offy intake, Edelbrock 600cfm 4 barrel, HEI 1966 Chevy C-10, motor and tranny went into the '68. Waiting to be restored.
#16009 11/25/2003 3:44 AM | Joined: Jun 2003 Posts: 54 Member | | Member Joined: Jun 2003 Posts: 54 | It gets stuck in 3rd gear. I have to push the linkage down to unstick it.
| | | | | Joined: May 2002 Posts: 14 Apprentice | | Apprentice Joined: May 2002 Posts: 14 | I have this same symptom in my '49 1/2-ton. Three speed on the column. It seems to happen at slow speeds - if I downshift before slowing, then I avoid the problem. Once stuck, I can't move the shifter and it stays in 3rd until I stop, open the hood, and pull up on the shift linkage.
Wondering if it is in the linkage adjustment, but I haven't wanted to mess that up by tinkering with it.
Any ideas out there?
Greg - 49 1/2 ton
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You need to pull the box on the column off & rebuild it. You can build up the worn parts with weld. Make shure all the linkages & bushings are free of play. The adjustment should be so the gearshift lever is in the same possition when you pull forward & back in neutral. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2002 Posts: 14 Apprentice | | Apprentice Joined: May 2002 Posts: 14 | The worn parts will be obvious? Corners off? I have checked the shifter position forward/back in neutral, per my shop manual, and that seems okay. Checked the linkages... appear okay, so you are probably right on the box internals. Just not sure what I should expect to see.
Thanks.
Greg - 49 1/2 ton
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Yes it will be pretty obvious when you get it tore down. The idea is to keep the selecter lever from getting between the 2 parts. If the shaft is loose you can rub the cover over some sand paper to narrow the holes. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2002 Posts: 14 Apprentice | | Apprentice Joined: May 2002 Posts: 14 | Thanks. Once I get some time, I will take a look. Appreciate the advice!
Greg - 49 1/2 ton
| | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Some times the culprit is actually the shifter arms on the transmission. I am talking about the arms the linkage bolts to. Years of shifting can loosen up the connections here, and even wear them significantly. Check to see you have good contact on the arms, and the keyway where it bolts.
