| | | Forums66 Topics128,047 Posts1,055,532 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 446 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 446 | The clutch in my '60 chatters when starting in 1st gear. It only does it after the truck is warmed up and has been driven for a few miles and it does it really bad on hot day's.
I'm planning to do a clutch job this spring but my question is why does it chatter after warm-up and hot days. Is the pressure plate warped and becomes more so when warm?
Iron Clad | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | most likely oil contamination, even slight from dirty fingers on assembly - good idea to have pressure plate and flywheel VERY clean when you replace the disc - even have resurfaced if they don't look real good
Bill | | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Soggy engine mounts can cause clutch chatter , dunno about the temp thing though. | | | | | Joined: Sep 2006 Posts: 206 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 206 | The pilot bearing could cause this also,alway's replace it when doing a clutch.Also I had one with a split driveshaft,it would chatter also.The carrier bearing was bad on that one.Tom | | | | | Joined: Jan 2007 Posts: 446 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 446 | Thanks guys, I will keep an eye out for these potential problems.
Iron Clad | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Clutch chatter is the clutch catching and releasing and catching again. The disk is probably oil soaked. Oil gets "sticky" on a clutch when it is hot, so the chatter gets worse. You will have to have the flywheel resurfaced when you do the clutch. It would also be a great time to replace the rear mounts and the pilot bearing, if need be, since you are right there.
If the clutch is oil soaked, You need to find out why, (rear main seal?,) and fix that as well.
best wishes,
Les | | | | | Joined: Jan 2007 Posts: 446 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 446 | Well I hope it's not the rear main. It never uses a drop of oil, the engine was rebuilt about 20,000 miles ago. I guess it wouldn't take much leakage though to make the clutch chatter.
Thanks for the advice, I will check this out as well.
Iron Clad | | |
