6 members (MikeStone1953, KEVINSKI, Jay R, 1955 1 Series, crenwelge, Hotrod Lincoln), 334 guests, and 5 robots.
Topics128,159
Posts1,057,027
Members48,460
I thought my sweat equity might help some other bolters out there. I am nearly finished installing a 49-52 Chevrolet passenger car fuel tank in the rear frame of my 65 C10 Shortbed.
I bought the new steel tank from Tanks, Inc. (FYI: Bob Drake is also selling these tanks now too, and for a few bucks less than Tanks, Inc.) The reason I used this tank is it does not stick down to low like a lot of these rear mount tanks do and the fuel filler neck comes out of the corner instead of the top.
Check out the photo at my Webshots Link. I also have included some CAD drawings I made for this configuration and for one that mounts flush with the top of the frame rails. If you need additional photos or information let me know.
http://community.webshots.com/user/lakeroadster
Gas Tank Sending unit http://www.brotherstrucks.com/prodinfo.asp?number=ATK59SU
P/N ATK59SU 47-87 UNIVERSAL GAS TANK SENDING UNIT 0-30 ohms
Apprentice
Apprentice
Hot Rod John,
Nice work. I like the way the tank fully fills the space from the pan hard rod mount/cross member all the way back to the tail cross member.
It looks to be about 20 gallons, is that correct? How high does the tank & upper mount measure from the top of the frame? Do you think the upper mounts will interfer with the cross sills for the bed?
Blue 666
A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools.
Blue666,
* I measured the external dimensions of the tank and ran the numbers. The tank capacity is 15 gallons.
* The distance from the frame to the top of the supports is 2 inches. The rear main cross sill will be relocated. The plan at this point is a marine plywood floor, with the plywood actually resting on the upper gas tank supports. I also plan to put access covers in the floor to gain access to the sending unit.
* Here is a link to the Tanks, Inc. web page for the tank.
That looks good.
I have been looking for another idea for my 64.
I didn`t particular like the way the aftermarket tanks hung down so low, either.
Thanks, Mike
Good work John. I'm sure a bunch here will be looking to follow your lead.
~Jim
That's a really nice job. Your truck sure looks better with the correct rear fenders, too.
Great pictures! Thanks for posting.
Best wishes,
Les
Socket Breaker
Socket Breaker
Very nice work!
What kind of a door to the fuel cap do you think you will wind up using?
Thanks for sharing the pics.
-W
What type of filler door you ask... are you ready for this? How about a 37 Ford passenger car filler neck and cap.
Just spent the day widening my stepside bed 4 inches today. Yeah, I know, I am wierd big_eek I did this for more rear tire clearance and just so it looks better: This will hide the indentations on the back of the cab & the stepside beds are actually narrower than the front width of the truck at the front fenders, to me that is backwards.
I could have bought the wider fenders, but to me those just don't look right.
I will post some pictures as things progress a bit further.
Here is a link to the thread about widening the bed
https://www.stovebolt.com/ubbthread...n&topic=0&Search=true#Post517710
