1 members (Hotrod Lincoln),
57
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | I have to replace the gasket in the narrow end of the Ball cover ('50 1/2 ton), as I have a new gasket intall kit. Does the narrow end of the ball cover unscrew to replace the gasket, or just put it in place as is. I tried to unscrew it after soaking it, and it's still tight! Thanks, Mike | | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | I don't quite understand what your talking about. Can you post a picture or send one to me? I've done several of these. There is a snap ring that has to be removed and maybe this is what is holding you up. Cecil........ | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Yes, there is a thin cap on the rear portion of the ball cover. Try putting a pipe wrench on it and giving it a twist. Thats how I ended up removing mine.
Good luck! Jeff | | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | it's the ball,universal: part# 5.564 in the master parts catalog tried it in the vice, after soaking with Kroil, guess I'll try again, maybe some heat and a few taps with a hammer to shock it. Mike | | |
