5 members (Donf, rfs56trk, DoubleB, BillCollins, Wally / Montana), 58 guests, and 3 robots.
Topics128,090
Posts1,056,022
Members48,430
#517598 03/16/2009 2:51 AM
I have to replace the gasket in the narrow end of the Ball cover ('50 1/2 ton), as I have a new gasket intall kit. Does the narrow end of the ball cover unscrew to replace the gasket, or just put it in place as is. I tried to unscrew it after soaking it, and it's still tight! Thanks, Mike
I don't quite understand what your talking about. Can you post a picture or send one to me? I've done several of these. There is a snap ring that has to be removed and maybe this is what is holding you up. Cecil........
Yes, there is a thin cap on the rear portion of the ball cover. Try putting a pipe wrench on it and giving it a twist. Thats how I ended up removing mine.
Good luck! Jeff
My 1953 Chevrolet
1947.1 Gallery
it's the ball,universal: part# 5.564 in the master parts catalog
tried it in the vice, after soaking with Kroil, guess I'll try again, maybe some heat and a few taps with a hammer to shock it. Mike
