1 members (baldeagle),
52
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,004 Posts1,055,246 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 66 | I'm using a special tool i bought at a swap meet that bolts in place of the water pump for a 55-62 235 and has a garden hose fitting on in to flush out the engine. The problem is that i can't seem to get water to come out of the drain at the back driver's side of the block due to some blockage. The engine has less than 500 miles since rebuild and i just acquired it so i really don't want to use harsh chemicals in fear of ruining the seals. Any suggestions?
Mike | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Did you remove the drain plug and try a wire in there to see if its open?
Otherwise you'll need a bigger plunger to get a 235 to flush.
Grigg | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | remove the pet cock. take an 1/8th inch welding rod (after stripping it)and rod it in there. it may take a while but you'll get it in all the way. swish it around while working it in. have plenty of water and patiences until there is nothing left to remove. then put some radiator flush in and follow directions on the label. every so often drain the block until no dirt is visible. thats what i had to do to three trucks. sounds like they didnt do a shake and bake before the rebuild | | | | | Joined: Jun 2004 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 66 | thanks for the suggestions | | | | | Joined: Jun 2004 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 66 | I tried running wire and cable with a drill through the petcock pork with no success. What are the dangers and benefits of radiator flush. What does it do to head gaskets, hoses, etc? | | | | | Joined: Jun 2004 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 66 | I meant petcock port not pork(must be hungry, lol) | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | on my forty i had to actually tap the welding rod(1/2 rod) in with a hammer. i tapped the rod in so far that it was almost flush with the block. i needed my vise grips to be able to pull it back out. when i did nothing came out and the system was full. no off the shelf flushes will touch this stuff. so dont waste your money as a matter of fact spend it on beer that way you got something to drink when your rodding it out. as soon as you get the rod in the hole "beer". when you get a dribble "beer" when you get a flow "beer". it will be easier to flush yourself than the block.
it took me hours. and i dont even drink. | | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | I've always reversed flushed my stuff. Get a tee fitting and take the top heater hose loose from the motor. Get another piece of hose and connect it to where you took off the hose and put the tee between the two. Connect your garden hose to the tee and take off the radiator cap. If there is a valve in the heater hose to shut off water to the heater core open it. With a thermostat in place it will stay closed using cold water and the water will be forced down thru the motor and up the lower rad hose and thru the radiator and out the top, back flushing the system When the water runs clean your done, pull off the tee and small hose and reconnect the top heater hose. Don't forget the anti freeze. Dan
Remember your freedom - US Veterans provided it. 101st Screaming Eagles
| | | | | Joined: Jun 2004 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 66 | I'm trying muriatic acid and i'm going to see what that does. | | | | | Joined: Jun 2004 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 66 | The muriatic acid worked!! When I get the engine running I'll send pictures of how I made it work. Woo Hoo!!!!!!!!!!! | | | | | Joined: Mar 2009 Posts: 169 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 169 | did you drink the acid? I thought Dan said to drink beer? glad it worked! | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Stoveboltkid ,
I'm really looking forward to the pictures and a bit more info.
Best wishes,
Les | | | | | Joined: Feb 2004 Posts: 29,740 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,740 | I've used acid to clean some really nasty cooling systems, including a fleet of concrete mixers I maintained. It's important to neutralize the acid by dumping a couple of boxes of baking soda into a fresh water fill after draining the acid wash. Run the soda mix for 10-15 minutes, then flush again with clear water. Refill with a 50/50 antifreeze/water mixture and you're good to go! Jerry
| | | | | Joined: Jun 2004 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 66 | So just running a whole lot of water several times won't cut it? | | | | | Joined: Sep 2005 Posts: 13 New Guy | | New Guy Joined: Sep 2005 Posts: 13 | After 5 min. of flushing it will be so clean your mother in law could drink it.
Gord
