| | | Forums66 Topics128,078 Posts1,055,936 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 6 New Guy | | New Guy Joined: Mar 2009 Posts: 6 | I need to Re-wire my truck. I wanna replace all the wiring in the whole truck. Anyone know if they make a kit for this kind of project? How much work am I getting into?
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Ed, there are several companies that make these kits. There is Painless wiring, YNZ and a few others. I believe there may be some listed in the links here on the bolt. Check them out. Also some of the vendors offer their own wiring harness kits. Maybe someone with your exact model will chime in before long but sometimes on the weekend things may get a little slow around the garage here as the Bolters are taking their wifes out for dinner on the weekends so they can work on the bolts during the coming week  EDIT: I checked the links under "electrical" and there is about 9 different ones listed. As mentioned above perhaps someone with your model and experience with the a vendor will jump in here.
| | | | | Joined: Oct 2008 Posts: 321 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 321 | This is a time consuming project but it is one that is well worth the effort. The big question is which way you want to go with the electrical system. Do you want to update it with more circuits and such, or do you want to go with straight stock replacement?
I have not done anything other than using stock replacement harnesses, and for the '60-'66 trucks there are a lot of places that carry the harnesses. I just bought a bunch of harnesses from Classic Parts for my '63, and they slap right in just like the old stuff with all the same connectors. Like Achipmunk said, check the Links page for electrical vendors.
The thing with the wiring is to plan it out and know exactly what you want to do before jumping in. Take lots of pictures as you work on removing the old wiring so you can refer back to them to see how things were routed. It isn't all that hard to replace the wiring, just go slow and don't rush it and you will have it done in short order.
1963 Chevy C20 Longbed Stepside 1978 Chevy K30 Custom Deluxe
