1 members (Southerntruck),
73
Mod | | | Forums66 Topics128,049 Posts1,055,635 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Has anyone done it? I want to keep my orig. column shift, but install a Saginaw 4 speed open drive. Im planning on using a "T" handle with a cable for reverse,,like an overdrive in/out cable. Has anyone tried this and made it work? What probs. did you run into? Im expecting some shift rod fabrication. Thanx in advance for your help, Marty | | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | MARTY I DID IT ON MY 47 FLEETMASTER 15YEARS AGO 1ST-4TH GEAR WAS ON THE TREE, AND REVERSE, WAS A LITTLE METAL SHIFTER OR LEVER ON THE FLOOR. WHEN I WANTED TO BACK UP I WOULD PUT THE COLUMN IN NEUTRAL, AND PULL THE LITTLE LEVER ON THE FLOOR INTO REVERSE | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Jeff and John, Thanks alot for the tips. The pictures from Motionguru's project will really help. | | |
