Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (UtahYork, 66flea, 50Chevy3100), 168 guests, and 3 robots.
Topics128,284
Posts1,058,523
Members48,490
#51633 10/29/2005 1:12 AM
it seemed like a good idea to get the coker whitewall tires for my 1/2 ton chevy and they look great but no one wants to mount them with tubes and they are hard to balance...
who can balance them correctly???
thanks for any help
I am en route to Ft.worth tex and need some quick advice this pm.
they bounce a lot...
#51634 10/29/2005 1:52 AM
I don't know about your area, but I'd call all the family owned shops- older the better, possibly, in this case. I'm sure you'll find an old timer that has no problem doing them. You might even try a farm or heavy equipment tire shop- they're used to funky stuff like tubes, split rims, etc. If you're not going to be driving this everyday, i wouldn't worry much about balancing them. All you can do is have someone put them on the machine and try it.
#51635 10/29/2005 2:22 AM
thanks I will check it out..
#51636 10/29/2005 3:46 AM
I don't understand why they don't want to mount them. But then if they've never seen them....
A friend of mine got net tires/tubes for his Morgan. Required for older wire wheels since they would otherwise leak quite a bit. Anyway he got 2 flats in a few hundred miles. Turns out there was a sticker on each tube. If that is left in it enventually cuts into the tube. Just something to make your day while your motoring down the road.
40 Chevy 1/2 ton
#51637 10/29/2005 4:48 AM
I have no idea why your coming to Fort Worth, but there is a shop here that can fix any problem you have with tires. It's North Hills Tire. The owner is Mike Starks and the shop supervisor is Stacy. They can fix you up!
Joe smile
#51638 10/29/2005 6:33 AM
Les Schwab put their tires and tubes on my '62 w/split rims. They balanced them as well. Before I went in, I was told it would be difficult to find someone who would do that. They were the 1st ones I tried.
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
#51639 10/31/2005 5:44 AM
Most car tire dealers don't know how to mount tube tires. Look for an outfit that deals in truck tires, best if they're a locally owned independent.
Fred
52 3600
69 C-10
