5 members (Bill Hanlon, Gdads51, 50Chevy3100, Charles in CA, 1 invisible), 59 guests, and 6 robots.
Topics128,095
Posts1,056,078
Members48,433
#51584 10/28/2005 1:01 AM
Junior Member
Junior Member
1 Offline
If you want to remove just the Transmission, do you have to pull the rear-end? It looks like the torque tube makes it hard to pull things apart. We are changing an engine and rear-end with a parts truck, which should be installed first? .
Don't pull the rear end. Remove the fasteners that hold the bell, slip it back on the torque tube and take the U-joint apart. Then either drop the torque tube or tie it up high enough for the transmission to be pulled.
#51586 10/28/2005 12:01 PM
When I pulled my transmission, on a 51 1/2 ton, I had the same problem. I pulled the crossmember just under the u-jount and dropped the torque tube down. This left lots of room to pull the transmission.
Have fun.
Mark
1951 Chevy 3100
Some days you get the bear. Some days the bear gets you.
Put a ratchet strap around the tube and the rear cab crossmember. Lift until the bell touches the floorpan and it will stay out of your way. I could'nt remove my tranny crossmember as it's riveted in. I thought they all were.
Curt B.
You Tube
#51588 10/30/2005 12:30 AM
When I raised the torque tube up to the floor level I could not get the transmission out. It was hanging up on the u-joint in the TT. I decided to take out the crossmember which made it really much easier. I would rather drop the trans down than pull it up thru that opening in the floor.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
