| | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Can anyone tell me the difference between the flexible rear brake hose on a 1972 Chevy 1/2 ton with coil springs and one with leaf springs? Looking through the various FLAPS comes up with a hose for leaf springs while some of the other vendors list the parts with different part numbers between the two types of rear suspensions.
A blown wheel cylinder and new shoes is snowballing into more work then I had planned as I steadily destroy the brake lines and strip threads trying to get the fittings apart.
Thanks, Jeff | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | According to my MPB, '72 series 10 thru 30 and Blazer (except 11,000 lb axle) uses the same hose. Part # is 9757634.
I can sympathize about how a simple job turns into six or eight jobs before you are done. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy rustednuts, according to my Raybestos catalogue leaf spring hose is p/n BH36684 18 5/16" o.a.l., coil spring hose is p/n BH36683 20 1/2" o.a.l., hope that helps | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Thanks for the input and part numbers.
Using those numbers, it looks like the thread pitch on the 'T' is the same at 7/16"-24, but where the end attaches to the hard line from the MC is either 7/16"-20 (for #36683) or 7/16"-24 (for #36684). Looks like I get to order both and see which one fits.
Thanks again, Jeff | | |
