| | | Forums66 Topics128,052 Posts1,055,773 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | doubt you'll have any luck there Perry, unless you find someone who'd try to build'em up with spray weld [if that's even legal] and turn'em back down .... find some good drums to fit and drill the required holes
also, re that "Apache" designation, the name started in 58 as the PR moniker for light trucks [up to 1T] - in 60 it turned into a trim package, by 63 it wasn't used anymore, the "C" and "K" designations were in full swing
Bill | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I can't tell what's wrong with those drums. If they are only grooved, I would reuse them. I rarely turn the drums or replace them, but my trucks aren't daily drivers. So grooved drums will wear my linings quicker, but what little I drive, they will still last a long time, Scott | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Perry Dean, can you find any numbers on your drums? do you know if your truck has a 5000 lb. axle or a 7000 lb.axle in it? What kind of wheels do you have, Daytons, Budds, or Kelsey?
| | | | | Joined: Jan 2009 Posts: 86 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 86 | im not sure about spray weld but i have seen them set up wore out piviot pin holes and run a computor guided welder and lay 1 solid bead and build the metal up then lath it back like new the problem i see with this is the drum is cast steel i dont know if you can do this with cast steel | | | | | Joined: Jan 2009 Posts: 86 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 86 | they look to me to be wore down about a quarter inch with rounded edges | | | | | Joined: Jan 2009 Posts: 86 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 86 | how can i tell what axle i have the only numbers i have are from a chevy dealer for the six inch extion its 15510542 for the 5 inch extion its 3998267 from the chevy book i was told below is a pic of my front tire i dont know what kind it is http://s427.photobucket.com/albums/pp359/oldwestrnwear/?action=view¤t=dumptruck7.jpg
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Perry Dean, I think I may have found your drums. In the parts book there is a chart which shows the drums by part number, and the number of mounting holes, there is only one part number in the entire list which has twelve mounting holes. That GM number is 5737261 = Napa TWD2845 $200.00, hope that helps. | | | | | Joined: Mar 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 92 | How can you have a 10 bolt wheel and a 12 hole drum? Also, those are the wrong wheels for that hub. You need the smaller center hole wheel, Scott | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 48bigtrucks@work, those wheels fit just the way they are intended to, and as far as the holes in the drum are concerned, I went by the picture Perry Dean posted of his brake drum, the drum has an extension/hub bolted to it, for the wheel to mount to, it is quite common for the number of holes in the drum, or the pattern not to match the wheel bolt pattern. | | | | | Joined: Jan 2009 Posts: 86 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 86 | 3B thanks so very very much i have searched all over oklahoma city with no luck at all but with a lil help from a fellow bolter anything can be done i called napa here and gave them the numbers and in just a few seconds he said they had some in dallas they can have here in the AM.
agin thanks so much | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Perry Dean, you're welcome, I hope those are the correct ones, please let us know one way or the other once you have them. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Yeah, I forgot about that dually adapter. Oh well, Scott | | |
