2 members (Svcattle, baldeagle),
145
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,274 Posts1,058,432 Members48,489 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#51520 10/26/2005 3:37 PM | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Took my son to school in the 46 this morning and noticed a real strong gas smell. When I got home, I found my fuel pump to have gone bad, with gas squirting out of the bottom half/on the side.
Since I'm gonna be replacing it anyway (now) I was wondering... Is it worth the extra expense to go to a dual action fuel pump?
I plan on keeping the vaccum wipers, as I've not found anyone that makes a 6-volt wiper motor that will swap straight across for a 46. I really don't want to hack up the wiper motor cover on the header.
Any of you had any experience with these dual action pumps, or had any luck finding a good 6-volt electric unit? | | |
#51521 10/26/2005 3:52 PM | Joined: May 2001 Posts: 1,908 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,908 | I like my dual-action fuel pump and vacuum wipers. It pushes snow OK.
You might change your oil if there's a chance that gasoline got in there. I had a leaky fuel pump on a '75 Hornet which raised the level on the dipstick by a quart or two. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#51522 10/26/2005 4:26 PM | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Wally, Thanks for the reply. I didn't think about the oil, as it was squirting gas out the side, and onto the ground. But, better safe than sorry. (Cheap insurance)
I'm impressed that your wipers would push snow. That's actually better than I was expecting.
Might be worth the extra bucks to go with the dual action pump. | | |
#51523 10/27/2005 12:35 AM | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i just installed a dual action from advance auto and it works real well, no snow yet. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
#51524 10/27/2005 5:53 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Wally's right on the oil. Saturday we had to put a fuel pump in a 230. The truck used half a tank of gas to go just a few miles. Had oil coming out the dipstick hole. Drained between 3 and 4 gallons out of the crankcase. By all means, go with the double action pump if you're sticking with vacuum wipers. Well worth the investment.
Fred 52 3600 69 C-10
#51525 10/27/2005 10:04 AM | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | Also,do you have a vacuum reservoir tank? It helps,and bigger is better. | | |
#51526 10/27/2005 12:49 PM | Joined: Aug 2005 Posts: 212 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 212 | I have a queston on this subject. I just put the motor back in my 1953 two ton. I put a double action pump on but have not hooked anything up yet. What do I do about the original connection on the manifold for wipers? Do I just ignore it, or will it be the same as a vaccuum leak if I don't block it off? Also, the pump has what looks like two connections for hoses. One is marked "Wiper". What is the other one for? Is it an air intake? Thanks, Allen | | |
#51527 10/27/2005 1:24 PM | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Wiper: run that line to the wiper motor.
Other: run to original manifold (vacuum wiper) connection. | | |
#51528 10/27/2005 6:10 PM | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | I put a double in my 55.1. When I went up a hill without it, it stopped imediately. Now, it just slows down a little. My vac motor has not been rebuilt.
55 1st Chev.
#51529 10/27/2005 11:17 PM | Joined: May 2001 Posts: 1,908 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,908 | Jed,
I took my vacuum motor and squirted 3-in-1 light oil in all the openings and worked the lever back and forth. That helped a lot. Like Tim said, use your manifold vacuum in series as the "fore pump" for your fuel pump. This has worked fairly well for me 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#51530 10/27/2005 11:21 PM | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | TC,
Thanks for the clarification on the plumbing of one of these units.
I'm sure that would have been one of my future posts.
Wally, my motor seems to work pretty well as is, but doesn't sound like a bad idea.
The biggest issue I have with my 46, is keeping the windshield wiper arm from flapping around in the wind, while I'm driving down the road.
The dual action pump won't help with that, but it sounds as though, I'll get alot better and more consistent service out of the wiper motor.
Sounds like I better look at doing the same to my 52, while I'm at it.
Thanks for all of the replies. | | |
#51531 10/28/2005 12:56 PM | Joined: Aug 2005 Posts: 212 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 212 | Tclederman: Thanks for the answer. Seems obvious, but I never would have thought of it. I assumed the fuel pump created its own vaccuum. | | |
