1 members (Hanks custodian),
153
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,127 Posts1,056,679 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 9 New Guy | | New Guy Joined: Dec 2008 Posts: 9 | I have got an original 283 and 3spd in my 65 c10. It runs fine but a little on the worn side. The tranny is perfect(other than the floor shifter kit put in before I owned it). I've been looking for a rebuild kit for a 283 and can't seem to find one, any suggestions? On the transmission... what would bolt up and best cooperate with my 283? I'm not looking for great speed, just a good runner. Also need and ashtray. If anybody has any advice, I'd greatly appreciate it. | | | | | Joined: Dec 2007 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 37 | What type of trans do you want, an automatic or a different manual?
My 64 has ac and the ash tray is mounted under the dash just to the right side of the steering column. This may be the type of tray that you need? 1959 Apache 3200, Standard Cab, Big Window, Fleetside, 235/3spd, Original Paint 1964 C20 Standard Cab, Fleetside, 283/Power Glide, A/C, Pwr Steering, Pwr Brakes, NoSpin | | | | | Joined: Dec 2007 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 37 | Also the place that does your machine work on your 283 will be able to get an engine kit for you. They will use a few parts out of the kit for the block and heads and give you the rest to put the engine together. There should be a few offerings in different vender catalogs too. 1959 Apache 3200, Standard Cab, Big Window, Fleetside, 235/3spd, Original Paint 1964 C20 Standard Cab, Fleetside, 283/Power Glide, A/C, Pwr Steering, Pwr Brakes, NoSpin | | | | | Joined: Oct 2004 Posts: 128 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 128 | Northern Auto Parts offers a rebuild kit for your 283. I believe their website is www.northernauto.com If the web address is incorrect, just google Northern Auto Parts. It's listed under GM engine kits. John | | | | | Joined: Dec 2008 Posts: 9 New Guy | | New Guy Joined: Dec 2008 Posts: 9 | I did find a rebuild kit but it's kinda high. I'll check out the northern auto website. Don't know what kind of trans I want yet. I'd like a 4 spd man, may consider an auto though. Any suggestions? The ashtray I need is mounted in the dash above the radio. Thanks for the info. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The BW T-5 trans. from an S-10 or Camero is the way to go unless you want to do burn outs & speed shifing. The o-drive will make it cruise right down the road. Do a search. The has been gobs of posts on it & some info in the tech tips. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2005 Posts: 13 New Guy | | New Guy Joined: Apr 2005 Posts: 13 | somewhere in the back of my garage i have the ashtray however i took it out when i installed a mini-guage trio in the hole might give that a thought | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | The 283 is fgoing to be more expensive than a 350. I browse Northern Auto, like John1 states, summit, jegs and www.pawengineparts.com. | | | | | Joined: Jan 2008 Posts: 239 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 239 | Nothing runs like a 283. The only real difference is the pistons themselves. The gaskets and bearings all fit other engines. If you are not in an immediate need, keep an eye on auction sites for a set of pistons. I gave away a set of standard bore stock pistons a few years ago. I'm keeping the lightweight 11.5:1 set I have for a race engine.
The other option is to build a 350 or 400 with your stock intake and valve covers. The top end tin will disguise it as a 283, yet you'll have a bunch more torque, which is useful in a truck.
Devin
If you can't hose it out it ain't a truck
55 3100 63 Corvair Monza 64 El Camino 72 240Z 01 Suburban
| | | | | Joined: Dec 2002 Posts: 3,445 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,445 | I wouldnt bother rebuilding the 283 unless it's smoking or has a bunch of blowbye.
I've run a wore out 283 for about 10,000 miles over the past 8 years without a problem.
I recently rebuilt a 327, I used a machine shop that was connected to an autoparts store... pretty much everything the machinist needed was available through the parts store... They would even assemble the engine (for a price), but I assembled it myself.... and it even runs!!
| | | | | Joined: Apr 2005 Posts: 13 New Guy | | New Guy Joined: Apr 2005 Posts: 13 | ive got a tranny froma 76 chevy 3/4 ton that will bolt to your bellhousing use your old throw out sleeve/bearing cover to fit the bellhousing hole and a automatic driveshaft in the back or get all in one shot in a salvage its a heavier tranny might give it a shot best of luck | | |
