| | | Forums66 Topics128,185 Posts1,057,279 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 7 New Guy | | New Guy Joined: Feb 2009 Posts: 7 | Hey guys im running 38" mud tires on my 46 Chevy 1/2 ton (its on a 69 K20 4x4 chassis) and the front tires rub on the fenders. I was going to cut larger openings but I was told that 2 ton fenders will bolt right on and are wider and have bigger openings. Anyone know if this is accurate? | | | | | Joined: Jan 2005 Posts: 305 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 305 | yes it is true and thay are the same most big bolt fenders sell cheeper than the 1/2 ton also please snt cut up a set of 1/2 ton go with 1 ton bigger openings
ya I know a few rednecks.Thay all drive chevys to, Proud member of the Old Dominion Stovebolt Society AND A MARINE trucks range from 1942 1/2 ton to 1965 fire engine
| | | | | Joined: Feb 2009 Posts: 7 New Guy | | New Guy Joined: Feb 2009 Posts: 7 | Sounds good. I wont cut them up. Now my search for some big bolt front fenders begins. | | | | | Joined: Apr 2007 Posts: 458 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 458 | I'm not an expert on this, but I believe if you use big bolt fenders, you might have to use a big bolt hood and grill as well. I might be wrong, but that is what I've heard. I'm sure somebody here knows the facts.
George | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | The hood and grill are the same between models. The running boards are also different (shorter) as the 1 1/2 ton fenders extend further down where they meet the cab.
One thing to consider is how it will look with the rear fenders. It may look goofy with the larger opening in the front and smaller opening in the back, unless of course you have a flatbed.
Jeff | | |
