0 members (), 134 guests, and 4 robots.
Topics128,149
Posts1,056,818
Members48,456
Hey guys im running 38" mud tires on my 46 Chevy 1/2 ton (its on a 69 K20 4x4 chassis) and the front tires rub on the fenders. I was going to cut larger openings but I was told that 2 ton fenders will bolt right on and are wider and have bigger openings. Anyone know if this is accurate?
yes it is true and thay are the same most big bolt fenders sell cheeper than the 1/2 ton also please snt cut up a set of 1/2 ton go with 1 ton bigger openings
ya I know a few rednecks.Thay all drive chevys to,
Proud member of the Old Dominion Stovebolt Society
AND A MARINE
trucks range from 1942 1/2 ton to 1965 fire engine
Sounds good. I wont cut them up. Now my search for some big bolt front fenders begins.
I'm not an expert on this, but I believe if you use big bolt fenders, you might have to use a big bolt hood and grill as well.
I might be wrong, but that is what I've heard. I'm sure somebody here knows the facts.
George
The hood and grill are the same between models. The running boards are also different (shorter) as the 1 1/2 ton fenders extend further down where they meet the cab.
One thing to consider is how it will look with the rear fenders. It may look goofy with the larger opening in the front and smaller opening in the back, unless of course you have a flatbed.
Jeff
My 1953 Chevrolet
1947.1 Gallery
