7 members (1955 1 Series, Bill Hanlon, Otto Skorzeny, rfs56trk, DHedrick, Robert Crandall, klhansen),
123
Mod | | | Forums66 Topics128,087 Posts1,056,399 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#51432 10/22/2005 6:16 PM | Joined: Apr 2002 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 42 | Have a 1934 1/2 ton pickup. One of the fanblades just broke nearly completely through. Have not been able to locate a fan for 207 engine yet and am wondering if a 216 fan will work. Any info appreciated. wjb | | |
#51433 10/22/2005 8:58 PM | Joined: Mar 2005 Posts: 170 Member | | Member Joined: Mar 2005 Posts: 170 | What are the dimension of your broken fan? Bolt hole spacing, diameter and width of blades, etc. With more info we might be able to help. Steve | | |
#51434 10/23/2005 2:19 AM | Joined: Apr 2002 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 42 | ndnchf: Will get that info. I have now been told that only fans from 34-36 will work, both truck and auto, although the auto fan is a little smaller.
Thanks. wjb | | |
#51435 10/23/2005 5:11 AM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | I wonder if you can weld it back up, or is that too dangerous? | | |
#51436 11/03/2005 4:01 AM | Joined: Apr 2002 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 42 | I thought about that. Don't know how that would work out. I got a 34 car fan that I'm going to use, so, for now at least, won't have to find out. wjb | | |
#51437 11/05/2005 6:14 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | willie, Tony (truckedup) posted a note some time back about a plastic fan that he bought from one of the suppliers, maybe American Racing or JC Whitney. He trimmed the fan with a pair of snips. This may be something to look in to. Maybe you could get one and drill your own mounting holes. | | |
#51438 11/05/2005 6:43 PM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | You should alway closely inspect that OLD stock fan. I've seen several that had fine cracks and quite a few over the years that shot a blade completly through the hood. I always try to stand out of the line of fire around a running engines fan blade. | | |
