7 members (MNSmith, CandoBrent, 1955 1 Series, Bill Hanlon, Otto Skorzeny, GrandpasJimmy, Shaffer's1950), 75 guests, and 2 robots.
Topics128,077
Posts1,056,280
Members48,441
How difficult is replacing the front seal on the rear differential of a 47 3/4 ton truck? It is leaking right behind the driveshaft yoke. It has a bell shaped collar just behind the yoke and then there are 5 bolts holding on a steel flange. How tough is this going to be or does this job usually go fairly easy? thanks!! slowgoer
54 Chevy 5 window - 46 Chevy 1/2 ton
It's important to put it back together just as it is now. Any tighter and it's overhaul time, at least a total disassemble to replace the pinion sleeve. First off, I clean the yoke, the nut and the pinion very well. I then index the three with a paint line from the center of the pinion, across the nut and onto the yoke. Remove the nut and yoke, do your repair, and put the yoke back exactly where it was. Tighten the nut down until it snugs up and then tighten it until the paint marks line up just as they did before disassembly. Easy as that,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Thanks alot for the advice. I was wondering how much had to come off to do the repair and how critical it is to keep it in the same place. I think I can handle it using this info. slowgoer
Riding in the Passing Lane
After removeing the yoke you will have to pull that coller off as the seal is in back side of it. There is a thick cork gasket behind it. If its not available you can use RTV. You may need a puller to get the flange off. Yhey can be real tight. That rear end does not use crush sleeves so you can tighten the pinion on down & line up the cotter pin holes.
1972 Chevy c10 Cheyenne Super
If the yoke has to be taken off with a puller, what about putting it back on, will it have to be driven on with a hammer or will it slide on easily. The question is, if you use a hammer, how hard can you hit it without damage to gears or seals or something else? I have had several of these old trucks but I have never had to do any differential work at all. I will get started on this repair in a couple of days so I'll see how it goes. thanks again for the info! slowgoer
It won,t be too hard to get back on. Put a little grease on the splines. You won,t hurt anything tapping it on as long as you don,t mushroom the holes for the u-joint bolts. If you get it on far enough to get a few treads you can pull it in with the nut. You will need a large socket I believe 1 9/16.
