Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
9 members (Jon G, 3B, 68ironhead, baldeagle, Jay R, KEVINSKI, kades51, Joe H, 1 invisible), 78 guests, and 2 robots.
Topics128,004
Posts1,055,247
Members48,418
#512931 03/04/2009 7:14 AM
Apprentice
Apprentice
Ok guys Im still new to the pre 70s so bear with me.
I did a search on timing an read about a ball on the flywheel an
a hole in the housing. I did see a say 1/14 hole on the driver side when I was changing manifold gaskets is this the for mentioned Hole I need to locate the ball in?
If so where do I go from there I read 7/32" is this correct for a 55 235. Also I am not sure the age of flywheel if it is from the 53 216 will it matter?
They did everything funny in them day didn't they!!
Mark53 #512945 03/04/2009 9:15 AM
There is a hole there, but its the wrong one. I'm not sure why GM put a hole there, it just confuses people. You want the hole on the passenger's side, just above/behind the starter. It should have a little pointer in there if you look deep enough. I'm not sure what the 7/32" measurement is, just time it so #1 fires when the ball meets the pointer. You can probably run it advanced a few degrees from that if you want because modern gas is much higher octane than the old stuff and the compression on these engines is pretty low.
Paint & Body Shop moderator
4ontheFloor #512971 03/04/2009 2:35 PM
Here is a photo of the Flywheel BB . It takes a good light to see it.
Hoyt
hoyt #513094 03/04/2009 9:20 PM
Apprentice
Apprentice
So I just time it like any other car but use the ball on the flywheel instead of timing mark on the harmonic balancer
Mark53 #513104 03/04/2009 9:40 PM
Riding in the Passing Lane
Exactly
1972 Chevy c10 Cheyenne Super
