| | | Forums66 Topics128,012 Posts1,055,311 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 25 Apprentice | | Apprentice Joined: Feb 2009 Posts: 25 | Ok guys Im still new to the pre 70s so bear with me. I did a search on timing an read about a ball on the flywheel an a hole in the housing. I did see a say 1/14 hole on the driver side when I was changing manifold gaskets is this the for mentioned Hole I need to locate the ball in? If so where do I go from there I read 7/32" is this correct for a 55 235. Also I am not sure the age of flywheel if it is from the 53 216 will it matter?
They did everything funny in them day didn't they!! | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | There is a hole there, but its the wrong one. I'm not sure why GM put a hole there, it just confuses people. You want the hole on the passenger's side, just above/behind the starter. It should have a little pointer in there if you look deep enough. I'm not sure what the 7/32" measurement is, just time it so #1 fires when the ball meets the pointer. You can probably run it advanced a few degrees from that if you want because modern gas is much higher octane than the old stuff and the compression on these engines is pretty low.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Jun 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 388 | Here is a photo of the Flywheel BB . It takes a good light to see it. Hoyt | | | | | Joined: Feb 2009 Posts: 25 Apprentice | | Apprentice Joined: Feb 2009 Posts: 25 | So I just time it like any other car but use the ball on the flywheel instead of timing mark on the harmonic balancer | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
