2 members (Jon G, klhansen), 154 guests, and 4 robots.
Topics128,196
Posts1,057,396
Members48,469
So, I've got all this 1/4" line laying around, and fittings and such. If I use the 1/4" from the pump to the carbs, is the engine going to starve, I can't see the 216 using more fuel than this. I realise though, the stock line is 5/16. But I like shiny stuff, and well, that's about it. Just general maintenance, and putting a better filter on.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
My uneducated guesstimate is that it would be fine. The fuel bowl holds lot of juice and the fuel pump transfers lots of juice and the poor old tiny carburetor doesn't use much juice, even at WOT.
Stuart
CARBS? I believe your line should be larger for multiple carbs. Stock should work, but I definetely wouldn't undersize it.
YIKES...it does say 'carbs'. eek While I still think 1/4" might work, I'm going to side with the Swingdaddy and say don't go smaller than stock size.
It's my understanding that two carburetors does not equate to twice as much fuel, but actually almost the same amount, but better distributed on the intake.
This is why it's important to reduce the venturi size on the dual install carburetors. They are now flowing at half the CFM each (of the engine), which means half the fuel each...does this sound correct!
Stuart
Yeah, I'm a little vague on all this stuff, though I'm following california Bills instructions, how can I go wrong? Hahaha.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
My dad used to run a 427 with a 6-71 blower and a pair of 4 barrels, and if he remembers correctly, 1/4" line. He may have used 5/16", but never any bigger on any of his rides. I really doubt youd have any problems with 1/4" on a 216.
Jeff
My 1953 Chevrolet
1947.1 Gallery
Think about the size of the hole at the tip of the needle valve. All of the gasoline has to pass through it.
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
Ahh, that's true isn't it! It has to go through that tiny little hole. I think I'm break out the NeverDull.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
Apprentice
Apprentice
Not trying to steal this thread, but i have a similar question. Will 1/4" line starve my 454 w/4bbl carb? I want to use an old elec. fuel pump and thats what size the fittings are. Don't really want to use adapters.
Rust Lover
I just used a steel 5/16 off the rack brake line to replace the 1/4 in copper line on my 216. It appears to be a great improvement. I also put in an inline filter using rubber fuel ine connectors that I hope will deal with the vibration as well.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
