7 members (3B, Tinker5, Gdads51, Bill Hanlon, Bills Auto Works, WICruiser, 2-Ton),
135
Mod | | | Forums66 Topics128,195 Posts1,057,378 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | So, I've got all this 1/4" line laying around, and fittings and such. If I use the 1/4" from the pump to the carbs, is the engine going to starve, I can't see the 216 using more fuel than this. I realise though, the stock line is 5/16. But I like shiny stuff, and well, that's about it. Just general maintenance, and putting a better filter on.
Thanks | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | My uneducated guesstimate is that it would be fine. The fuel bowl holds lot of juice and the fuel pump transfers lots of juice and the poor old tiny carburetor doesn't use much juice, even at WOT.
Stuart | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | CARBS? I believe your line should be larger for multiple carbs. Stock should work, but I definetely wouldn't undersize it. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | YIKES...it does say 'carbs'.  While I still think 1/4" might work, I'm going to side with the Swingdaddy and say don't go smaller than stock size. It's my understanding that two carburetors does not equate to twice as much fuel, but actually almost the same amount, but better distributed on the intake. This is why it's important to reduce the venturi size on the dual install carburetors. They are now flowing at half the CFM each (of the engine), which means half the fuel each...does this sound correct! Stuart | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Yeah, I'm a little vague on all this stuff, though I'm following california Bills instructions, how can I go wrong? Hahaha. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | My dad used to run a 427 with a 6-71 blower and a pair of 4 barrels, and if he remembers correctly, 1/4" line. He may have used 5/16", but never any bigger on any of his rides. I really doubt youd have any problems with 1/4" on a 216.
Jeff | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Think about the size of the hole at the tip of the needle valve. All of the gasoline has to pass through it. | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Ahh, that's true isn't it! It has to go through that tiny little hole. I think I'm break out the NeverDull. | | | | | Joined: Feb 2009 Posts: 26 Apprentice | | Apprentice Joined: Feb 2009 Posts: 26 | Not trying to steal this thread, but i have a similar question. Will 1/4" line starve my 454 w/4bbl carb? I want to use an old elec. fuel pump and thats what size the fittings are. Don't really want to use adapters.
Rust Lover
| | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | I just used a steel 5/16 off the rack brake line to replace the 1/4 in copper line on my 216. It appears to be a great improvement. I also put in an inline filter using rubber fuel ine connectors that I hope will deal with the vibration as well.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | |
