1 members (Wickedbass),
33
Mod | | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 179 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 179 | Hi guys,my wife bought me an am/fm radio for my 57 1/2 ton.It fits into the original opening in the dash,did'nt want to cut the dash up.Any way i have 2 10" speakers in the cab corners behind me and i would like to put 2 more where the vents are in front.That means i block the air flow.Good idea,bad idea your thoughts please.
roy | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | | | | | | Joined: Jun 2007 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 90 | Good idea for a custom cab with air conditioning, bad idea for a stock cab especially when that extra airflow counts on a hot summer day. You'd regret it. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I wouldn't want to disrupt the airflow through the cab. I think it could lead to condensation problems on humid or rainy days. Ain't nuthin' worse than a damp interior!  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I'm with the rest, bad idea. There are better solutions, though. 1 would be to use the speakers that mount in the factory location above the inside rearveiw mirror. The speakers and the housing are available from many of the suppliers in the Links section. Those will require drilling into the inside cab roof (4 mounting holes and a wire access hole) and some tricky wire routing through the A pillars. Option 2 would be to get the kick panel speakers. Those include new kick panels (actually, the hinge access panels) that have a surface mount style speaker built into them. I'm not too familiar with the installation on these, as I went with the stock location style speakers.
Bill Burmeister | | |
