9 members (Jay R, 68ironhead, Bill Hanlon, baldeagle, kades51, 3B, carbking, Jon G, 1 invisible),
77
Mod | | | Forums66 Topics128,004 Posts1,055,247 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | What wheelbase lengths were available on the '60-'66 panel delivery trucks and Suburbans?
I'm thinking, if I end up keeping my panel truck, to swap the body onto a '73-'80 frame and running gear.
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass. Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | 115" on 'Burbs and 1/2 ton Panels, 1 ton Panel wa 133". The '73-'80 pickups were 117.5 (1/2 ton short), 131.5 (long), and 129.5 ('Burbs). Doing the front crossmember swap might be a better option than an entire frame swap.
Bill Burmeister | | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | I was thinking the same thing! That will make things a ton easier, to be sure!
