| | | Forums66 Topics128,126 Posts1,056,354 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#51134 10/14/2005 2:55 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I've got an old 50 3100 pick-up lying aroung and I'm thinking of building a street/rat rod type thing out of it for my wife. She would really like to join in the fun, but it needs to be more user friendly. Don't worry, it's no cream puff, engines locked up, body parts missing, etc., etc. What I want to know without having to crawl under this thing out in the field is, how wide are the axles from outside drum to outside drum? I'm looking at a V-8 equipped mid 70's Nova as a drivetrain/suspension donor and wonder if it's narrow enough to fit under the 3100. Narrower would be O.K. but not wider. I don't like the "tires out past the fenders" look. Anyone got there old diff's available for a quick measurement? Thanks, Scott | | |
#51135 10/14/2005 3:18 AM | Joined: Aug 2004 Posts: 476 Moderator | | Moderator Joined: Aug 2004 Posts: 476 | Scott, According to the Chevrolet Truck Data Book I picked up from Chevy Duty, it is 59&9/16, center to center on the front tread.
Remind me to show you the book sometime. I have heard that Novas, Camaros and the smaller Monte Carlos make good donors for rear axles and front frame clips.
Don't lose your head to save a minute, You need your head, your brains are in it. Burma-Shave (1947)
#51137 10/14/2005 12:03 PM | Joined: Mar 2005 Posts: 158 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 158 | Your Nova donor sounds perfect.
I was told (by someone who claimed to have done it) that the Nova rear (up to '78) leaf spring perches are perfectly spaced to fit our ADs.
Turn the springs around to center the wheels in the wheelwells, and GO.
I have not confirmed this yet, but I trusted his word enough to buy a rear set up for a Nova. It's sitting in my garage, waiting for me to get the frame stripped and powdercoated. Just haven't got to it yet.
If you get it installed before I do, could you let us know "for sure"?
Hope this helps. mark. '51 KY 3100 | | |
#51138 10/17/2005 3:53 AM | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | My 54 is 62 1/4" mounting surface to mounting surface. | | |
