3 members (1955 1 Series, Millenimech, Nick in Manitou), 73 guests, and 2 robots.
Topics128,032
Posts1,055,438
Members48,422
#510860 02/26/2009 10:37 PM
can you run an engine on the floor in the garage? w/ gas, battery etc.? to test it to buy it?
56 stepside 3/4 ton longbed
I've done it, but other than establishing the fact it will run, there's not much a quick runup will accomplish. There's no way to put it under load, or even keep it cool unless you've got a garden hose piped to the water pump inlet. It might be possible to check oil pressure, and listen for major knocks, but it's a pretty messy, time-consuming project with not much to show for it. I check mine out on an engine dyno, where I can run for several hours if necessary, and do controlled load testing.
With a load on it, it will set rock solid, no torqueing over or rocking around. You will be suprised how steady it will run and how quick it rev. Joe
