| | | Forums66 Topics128,040 Posts1,055,478 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2002 Posts: 159 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 159 | can you run an engine on the floor in the garage? w/ gas, battery etc.? to test it to buy it?
56 stepside 3/4 ton longbed
| | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | I've done it, but other than establishing the fact it will run, there's not much a quick runup will accomplish. There's no way to put it under load, or even keep it cool unless you've got a garden hose piped to the water pump inlet. It might be possible to check oil pressure, and listen for major knocks, but it's a pretty messy, time-consuming project with not much to show for it. I check mine out on an engine dyno, where I can run for several hours if necessary, and do controlled load testing. Jerry
| | | | | Joined: Feb 2000 Posts: 5,197 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,197 | With a load on it, it will set rock solid, no torqueing over or rocking around. You will be suprised how steady it will run and how quick it rev. Joe | | |
